Garmin Device Not Receiving Smart Notifications From Phone
Most issues with not seeing notifications on your Garmin device are solved by correcting a setting on your paired phone. Review the following FAQ carefully to ensure both the settings on your phone and your Garmin device are configured correctly.
Select your phone type below to reveal instructions on how to manage which notifications you see on your Garmin device.
iOS
The following settings are for phones running iOS 16 or higher. To ensure the best possible compatibility between your phone and your Garmin device, make sure that your phone's operating system is up to date.
Step 1: Check iOS Bluetooth Settings
Open the Settings app on your phone and select Bluetooth®.
Ensure Bluetooth is toggled on.
Under MY DEVICES select thenext to the name of your Garmin device.
Your phone settings should look like the screenshot below. Turning on each setting allows full functionality of the Garmin Connect app and the device you have paired to the app.
Step 3: Review iOS App Notification Settings
The setting recommendations under this step are required by Apple to display notifications on a Bluetooth® paired device.
From the iPhone Settings, select Notifications.
Ensure that Show Previews is set to either Always or When Unlocked. This is an Apple requirement for any app that you want notifications to display on your Garmin device.
Step 4: Review Notifications Settings For Each Application
IMPORTANT: You will need to follow the steps below for each app you want to receive notifications from. Below is an example for Messages.
Select an application you want to receive notifications from. Example: Select Messages.
Ensure Allow Notifications is enabled.
Ensure the Notification Center has been check-marked .
Ensure Show Previews is set to Always (Default) or While Unlocked.
Step 5: Review Focus Settings
Focus allows you to customize when you receive alerts and notifications on your phone. Focus profiles can be enabled by schedule, location, or they can be manually turned on. When this happens you will not receive a pop-up notification on your Garmin device. Notifications will still display in your notifications widget. To check the settings of this feature:
Open the Settings on your iPhone.
Select Focus.
Review each Focus profile. Any that are listed as on will prevent you from seeing notifications on your Garmin device:
Step 6: Confirm iMessage Contact is Not Muted
If you have muted a contact in the past, check to see if that is the reason why you are not seeing notifications from that specific contact.
Open the Messages app on iPhone.
Slide right to left on a thread in the messages list.
The image below shows a contact that has not been muted. If the contact has been muted the bell icon will not have the slash through it.
Android
To ensure the best possible compatibility between your phone and your Garmin device you want to make sure that your phone is on the latest available version of the operating system.
Toggle to enable or disable smart notifications from All Applications or customize by selecting individual applications from which you would like to receive smart notifications
Some Android apps deliver persistent notifications to your phone that cannot be dismissed. An example of this is reminder apps. These types of notifications are not shared from the phone to the Garmin device due to a priority setting. If you frequently use these kinds of apps, you need to rely on your phone to see those notifications.
Apps Installed to a Samsung Knox Secure Folder Will Not Display Notifications on Your Device
Some Samsung phones have a Secure Folder feature that allows apps to be isolated from the rest of the phone. Although a Garmin device may be paired with a phone that has this feature, any apps installed into this Secure Folder will not be able to have their notifications displayed on your Garmin device, even if the Connect app is installed to this Secure Folder as well. If you have apps with notifications that you need to be shown on your Garmin device, install both the Garmin Connect app and the apps in question outside the Secure Folder.
Check the Settings on your Garmin Device
Recommendations below will vary by model. For specific steps see your owner's manual.
Confirm Bluetooth® is on. This setting is usually found under Settings > Bluetooth/Phone.
Confirm the Notification widget/glance is turned on. This setting is usually found under Settings > Widgets/Glances or in the Garmin Connect™ app under your Device Settings > Appearance.
Ensure that the watch settings reflect your choice of notifications you wish to receive (e.g., on, off, show calls only, show calls and texts only, etc.). This setting is usually found on the watch under Settings > Connectivity/Phone > Notifications.
Confirm Do Not Disturb is set to off. This setting is usually found on the watch under Settings > System > Do Not Disturb. You can also check in the Controls Menu.
Confirm battery saver mode is disabled. On compatible devices, this is usually found in the watch under Settings > Power/Battery Manager > Battery Saver. To confirm compatibility refer to your owner's manual.
Restart both the phone and Garmin device. If this does not resolve your issue continue to the next section.
Confirm That Your Sleep Settings are Correct
Sleep time settings in the Garmin Connect app enables Do Not Disturb preventing notifications from displaying on your Garmin watch. For instructions on how to check and make sure your sleep times are correct see - Setting Sleep and Wake Window Times in Garmin Connect.
