Nutrition and Hydration Tracking on Edge Devices
Some Edge devices allow you to record the calorie and fluid intake when you save a ride of a specified duration. This may be helpful for a variety of reasons, such as coaching purposes, or comparing consumption demands in different environments. To verify your device has this feature refer to your owner's manual.
To Enable Nutrition/Hydration Tracking:
  1. Select Menu or Three black lines vertical stacked.
  2. Select Settings (Edge 530 only).
  3. Select Activity Profiles.
  4. Select a profile.
  5. Select Nutrition/Hydration.
  6. Select Track Consumption to enable.
  7. Select Minimum Ride Duration to adjust the ride time required for the prompt.
  8. Select Volume to set units to ounces or milliliters and Bottle Size to adjust bottle size.
When you are finished recording your ride, you will be prompted to record the Calories Consumed and Fluid Intake. The Edge may show an estimated calorie and fluid consumption, however you can adjust this to the actual amount consumed. Your calorie consumption and fluid intake will then be saved to the summary for the ride and will also appear in the activity summary in Garmin Connect  or the Garmin Connect App when you sync your device.
Edge prompting consumption screennutrition and hydration summary in Garmin Connect
