Garmin Chartplotter Requirements to Commission the Reactor™ Autopilot
A Garmin chartplotter with software 4.50 or higher can commission the Reactor™ marine autopilot systems. Directions for commissioning the autopilot are found in the Configure Manual for the Garmin marine autopilot systems.
The following Garmin chartplotters do not require a GHC™ autopilot helm controller to commission the autopilot system:
GPSMAP® 90xx chartplotter | GPSMAP® 92xx chartplotter
GPSMAP® 86xx chartplotter | GPSMAP® 84xx chartplotter
GPSMAP® 8530 chartplotter| GPSMAP® 8500 chartplotter
GPSMAP® 82xx chartplotter | GPSMAP® 80xx chartplotter
GPSMAP® 76xx chartplotter | GPSMAP® 74xx chartplotter
GPSMAP® 10x2 chartplotter | GPSMAP® 12x2 chartplotter
GPSMAP® 7x2 chartplotter | GPSMAP® 9x2 chartplotter
GPSMAP® 7x3 chartplotter | GPSMAP® 9x3 chartplotter | GPSMAP® 12x3 chartplotter | GPSMAP® 16x3 chartplotter
ECHOMAP™ Plus 64cv chartplotter | ECHOMAP™ Plus 7x chartplotter |ECHOMAP™ Plus 9xchartplotter
ECHOMAP™ UHD 6x chartplotter | UHD 7x chartplotter | ECHOMAP™ UHD 9x chartplotter
ECHOMAP™ UHD2 6Xsv | UHD2 7Xsv | UHD2 9Xsv
ECHOMAP™ Ultra chartplotters
ECHOMAP™ Ultra 2 chartplotters
Yamaha CL7
All other Garmin chartplotters will require a GHC dependent on the autopilot system installed.
Notes:
• The ECHOMAP™ Plus 63cv does not have a NMEA 2000 port
• The ECHOMAP™ Plus 64cv and UHD 6x chartplotters require the use of a 4-pin Female to 5-pin Male NMEA 2000 Adapter Cable (010-12445-10)
