Garmin Instinct 2X Solar Torch Features
Instinct® 2X Solar watches feature an LED flashlight, referred to as torch, with the ability to adjust brightness, strobe, color, and activity settings.
Using the Instinct 2X Solar Torch
Quickly pressing the LIGHT key twice will enable/disable the built-in LED torch, which is located above the display between the watch bezel and the band:
When the torch is activated, it will use the last torch setting that was selected (strobe and distress pattern excluded).
Torch Settings for General Use
These settings are general use of the torch outside of activities. For settings during activities, see the section below.
- Press and hold LIGHT to access the Controls menu.
NOTE: If Torch is not in the Controls menu, you will need to add it to access the settings, see - Customizing the Controls Menu. - Select
. - The following options will be available:
Activities and App Settings
In addition to the options listed above, the Instinct 2X Solar can also be customized to use different light modes during certain activities. For example, it can be set to automatically activate a strobe light when running after sunset.
To adjust these settings:
- Hold UP/MENU.
- Select Activities & Apps.
- Select an activity.
- Select the activity settings.
- Select Strobe, then select an option:
- Status - Choose between Off, After Sunset, or On.
NOTE: After Sunset will use the sunset time determined by the watch, and will continue until 30 minutes after sunrise. - Mode - Choose between Blink, Pulse, Beacon, Blitz, or Cadence.
- Speed - Choose between Slow, Medium, or Fast.
- Color - Choose between White, or Red.
