Managing Storage Space on Your Garmin Outdoor or Marine Handheld
Garmin outdoor and marine handhelds have reserved internal memory for data, such as waypoints, routes, tracks, activities, and geocaches. Most also have a slot for a microSD card.
Handhelds have limitations on the amount of data they can read, regardless of whether the data is on the internal memory or microSD card. The limitations are more than a typical user needs.
As such, there is no benefit to placing data on the microSD card instead of keeping it on the device itself. The only reason for having a microSD card is to store additional mapping.
Understandably, the amount of data in the device can cause concerns about any adverse impact on the device's performance.
NOTE: User data created on the device can only be saved to the internal memory.
If you:
Think you may be reaching the limitations of your device
Want to be proactive in removing older data
Notice your device's performance is becoming slower
You can back up important user data from the device to the computer using our BaseCamp™ program, and then delete the data from the device via the computer too. For steps, see - Backing Up, Viewing And Transferring Data Using Garmin BaseCamp and Deleting GPX Files From an Outdoor Device.
For more details on checking the data limitations of your handheld and how much space you have available, refer to the sections below.
- User Data Limitations of the Alpha® 100 dog tracking handheld
User Data Limitations of the Alpha® 200 or Alpha® 200i dog tracking handhelds
User Data Limitations of the Colorado® 300 or 400 series outdoor handhelds
User Data Limitations of the Dakota™ series outdoor handhelds
User Data Limitations of the eTrex® Touch 25, 35, and 35t outdoor handhelds
User Data Limitations of the eTrex® 20, 20x, 22x, 30, 30x, or 32x outdoor handhelds
File Limitations of the Foretrex® 601 or Foretrex® 701 Ballistic Edition outdoor navigator
File Limitations of the Foretrex® 801 or Foretrex® 901 Ballistic Edition outdoor navigator
User Data Limitations of the GPSMAP® 62 or GPSMAP® 78 series outdoor handhelds
User Data Limitations of the GPSMAP® 64 series outdoor handhelds
User Data Limitations of the GPSMAP® 65 series outdoor handhelds
User Data Limitations of the GPSMAP® 66 series outdoor handhelds
User Data Limitations of the GPSMAP® 67 series outdoor handhelds
User Data Limitations of the GPSMAP® H1 series outdoor handhelds
User Data Limitations of the Montana® 600 series outdoor handhelds
User Data Limitations of the Montana® 700 series outdoor handhelds
User Data Limitations of the Oregon® 200, 300, or 400 series outdoor handhelds
User Data Limitations of Oregon® 450, 450t, 550, or 550t outdoor handhelds
User Data Limitations of the Oregon® 600 series outdoor handhelds
User Data Limitations of the Oregon® 700 series outdoor handhelds
User Data Limitations of the Rino® 600 series outdoor radios
User Data Limitations of the Rino® 750 series outdoor radios
NOTE: Many newer outdoor handhelds use Media Transfer Protocol (MTP) mode, which prevents them from being recognized as external drives on Mac computers. A Windows computer must be used to access the folders on these devices. For a list of outdoor handhelds that use MTP mode, see - Outdoor Handheld Devices That Do Not Show as a Drive on Mac Computers.
Connect the Garmin device to a computer.
Locate the drive for your device.
HINT: The drive will be labeled Garmin, or the name of your device.
Windows:
Press the Windows key + E on the keyboard to open Windows Explorer/File Explorer.
Select This PC (Windows 10 & 11 only).
Locate the drive for your Garmin device.
Mac:
Open Finder.
Select Go in the menu bar at the top of the screen.
Select Computer.
Highlight the drive.
Examine the drive's properties.
Windows: Right-click on the drive, and select Properties. If free or available space is not displayed, double-click the drive to open it, then right-click on Internal Storage and select Properties.
Mac: Press the space bar on the keyboard after highlighting the drive.
The free or available space should now be displayed.
