My GPS Fitness Device Does Not Show Speed or Distance Outside
If an older GPS enabled fitness device is failing to show speed or distance outside, it is possible the device may not have locked onto a satellite signal yet. If you are outdoors with an unobstructed view of the sky your device should acquire a signal within a few minutes. In cases where you've given the unit several minutes to acquire and it will not, there is the potential for some stored satellite data to become corrupted on the device causing it to not lock onto a satellite signal. In the event that this occurs, it may be necessary to perform a process called AutoLocate.
Perform the AutoLocate Function:
Edge 205/305 and Forerunner 101, 201, 205, 301, 305, 310XT, and 910XT
Ensure device is powered off.
Press and hold DOWN.
Press and release POWER.
Wait 30 seconds.
Release DOWN.
NOTE: For the Edge or Forerunner 205/305 if the issue continues, there may be an issue with the GPS Chipset software reporting version 0.00. Please see related content down below to troubleshoot the issue.
Forerunner 405, 405CX, and 410
If device is in low power mode, press Start.
Select GPS.
Select Satellites.
Press and hold RESET.
Wait 30 seconds.
Release RESET .
Edge 500
Press and hold LAP and START.
Wait 30 seconds.
Release LAP and START.
Edge 605 and 705
Press and hold OUT.
Wait 30 seconds.
Release OUT.
Forerunner 610
Ensure device is powered on.
Navigate to Main Menu.
Select Setup.
Select System.
Select GPS.
Select Satellites.
Press and hold LAP/RESETfor 7 seconds.
After you have performed AutoLocate on your device, allow up to 5 minutes to acquire GPS with an unobstructed view of the sky.
