Calibrating the 3-Axis Compass on a quatix
Garmin quatix devices have a 3 axis electronic compass built into the device for more accurate heading as compared to the GPS compass the unit has as well.
When the quatix is first used, the compass should be relatively accurate out of the box.
However, the quatix compass can be calibrated if needed.
To calibrate a quatix watch:
  1. Press the blue button
  2. Choose Setup
  3. Choose Sensors
  4. Choose Compass
  5. Choose Calibrate
  6. Choose Start
  7. Follow the onscreen commands to calibrate the compass
To calibrate a quatix 3 Smartwatch:
  1. Press and Hold the UP button
  2. Choose Settings
  3. Choose Sensors
  4. Choose Compass
  5. Choose Calibrate
  6. Choose Start
Once the instructions are completed, the compass will be calibrated.
