Getting Started With the Instinct Crossover
If you are setting up an Instinct® Crossover watch for the first time, the following steps walk you through the process to help you get the most out of it.
Setting up the Instinct Crossover Watch
When powering on the Instinct Crossover watch for the first time, you will be prompted to configure your user setting and preferences. These settings can be changed at any time.
Power on the Instinct Crossover watch by holding LIGHT/CTRL.
Learn About the Buttons
LIGHT/CTRL
Press to turn on the watch.
Press to turn the backlight on and off.
Hold to view the controls menu.
GPS
Press to view the activity list and start or stop an activity.
Press to choose an option in a menu.
Hold to view GPS coordinates and save your location.
BACK/SET
Press to return to the previous screen.
Press to record a lap, rest, or transition during a multisport activity.
Hold to view the watch face from any screen.
DOWN/ABC
Press to scroll through the widget loop and menus.
Hold to view the altimeter, barometer, and compass (ABC) screen.
UP/MENU
Hold to view the menu.
Choose your language by scrolling through the list using UP and DOWN, press GPS to select the language.
Pair the watch to your smartphone with the Garmin Connect™ app (optional). NOTE: Paring the watch with Garmin Connect will also register the watch.
