Distance/Time to Go Issue on Edge Segment Data Screen
If you imported your activity profiles from another device, it is possible that the Distance to Go and Time to Go data fields on your old segment page are no longer working on your new segment page. This is because new Edge models changed the mapping for this data to use different data fields.
How to Fix These Data Fields
Power on your Edge.
Select the menu icon on the screen
Select Activity Profiles.
Select the name of the profile you wish to change.
Select Data Screens > Segment > Layout and Data fields.
Select the
to accept the layout.
Double tap the appropriate data field to make these changes.
If you were or are using Distance to Go, change it to Distance to Next.
If you were or are using Time to Go, change it to Time to Next.
