Using the Garmin PowerSwitch App With Android Auto or Apple CarPlay
The Garmin PowerSwitch™ rugged 12V controller supports Android Auto and Apple CarPlay connectivity, enabling you to view and control digital switching functions from your vehicle's in-dash infotainment display by using the Garmin PowerSwitch™ app with a compatible smartphone.
To install the Garmin PowerSwitch app on a smartphone, please refer to Installing the Garmin PowerSwitch App for directions.
For information on using Android Auto with smartphone apps, please refer to Android Support.
Android Powerswitch
For information on using Apple CarPlay with smartphone apps, please refer to Apple Support.
Carplay Powerswitch
Note:  click images to enlarge in new window.
To Add or Remove the Garmin PowerSwitch App on Android Auto
1. On the Android phone, go to Settings.
2. Select Connected devices.
3. Select Connection preferences.
4. Select Android Auto.
5. Select Customize launcher.
6. To disable, uncheck the app, OR
7. To enable, check the app.
8. Optionally, to rearrange the apps:
  • Select Launcher sorting and select Custom order.
  • Select and hold the icon with six dots next to each app, then drag it up or down to the desired location and release. Do this with each app to arrange them as you wish.
To Add or Remove the Garmin PowerSwitch App on Apple CarPlay
1. On the iPhone, go to Settings
2. Select General
3. Select CarPlay
4. Select the CarPlay name being used
5. Select Customize
6. To disable, tap the Minus, then tap Remove, OR
7. To enable, scroll down to More Apps and tap the Plus
  • Select and hold the 3 lines to the right of the app to move.
  • Drag it up or down to the desired location and release. Do this with each app to arrange them as you wish.
