Go Home Option On the Edge 800
The Edge 800 does not have a designated "Go Home" feature, however it is possible to setup a similar function by walking through the following:
Setup a Home Option:
  1. Power on the Edge 800.
  2. Acquire Satellites while you are at home.
  3. From the Map, Select expand map.
  4. Select the position icon navigateicon.
    • This icon represents where you are on the map.
  5. Select Save and Edit.
  6. Select Change Name.
  7. Type out HOME.
  8. Select the green check mark save.
  9. Select Change Symbol.
  10. Select an appropriate icon.
  11. Changes will save.
Use the Home Feature:
  1. Select MENU.
  2. Select Where To?
  3. Select Locations.
  4. Select Home.
  5. Select Go.
The Edge 800 will navigate you to the Home location saved on your device.
