Verifying Maps Installed on an Overlander® Device
To See Which Maps Are Loaded to Your Device:
1. Touch the Settings wheel
 2. Touch Navigation
 3. Touch Map and Vehicle
4. Touch myMaps
5. Within this section, you will be able to see all of the mapping loaded onto the device.
If there is no check mark next to the map(s) you wish to use, touch the box next to the map to add a check. This will enable the mapping on the device.
See North America Map Regions for more information about coverage offered with North America mapping.
